Search Forums | Classifieds (15) | Skins | Language
Jumping onboard with gps
JoeR
Posted 12/29/2010 14:13 (#1513385)
Subject: Jumping onboard with gps
NW Iowa
I just bought a 750/ez steer setup and wanted to get some good pointers on running these...do's, dont's, etc. It'll be going in a NH 8870 for tillage this spring and probably in the 9500 this fall for beans. Plan on running WAAS for now. Couple questions come to mind right off...what guidance pattern(s) is suggested for running in terraced fields (several in different directions)...also, any other uses that you've come up with to use these for. I was planning on using it this fall to run a set of cameras for the grain cart, but that might be a little tricky if it's in the combine.
