Like it says, anyone using it this spring or even know anything about it? Will this be the cure to strip-till/planter drift woes?? How much extra cost? Hopefully be available for 9xx0 tractors in coming years? In talking with the dealer, he doesn't think much of combining corn even with RTK. iGuide coupled with RTK should take care of that and the problem of stripping and planting with different width planters, as well as allow spraying using autosteer as well if what I think is right? Looks like from Deere's press release their version moves the tractor to correct rather than coulters steering the implement. This should allow for more mobility between implements. |
