moisture tester for a dryer
1466i
Posted 11/14/2010 15:51 (#1435616)
Subject: moisture tester for a dryer
central Ohio
I put up a used Clayton Lambert Roto Flow. Was wondering if there is a moister tester that I could put in the dry corn flow to show the moisture as it comes out. Do not want anything fancy just want see the moisture as it comes out with out taking a sample to see if I need to change the speed of the dryer just to make it easier. Thanks
