4455 heat gauge
nbfarms
Posted 8/7/2010 21:16 (#1305396)
Subject: 4455 heat gauge
On our 4455 heat gauge, it seems that it does not get as "hot" as it used to/should. One day for some reason i turned the key off when i was working and then turned it back on, the heat gauge jumped up farther when i turned it back on. I talked to our dealer and the shop manager said that i shouldnt mess with the key, in a joking way, and said he wouldnt worry about it. Well, now when im working it hard(rpms around 2000-2100) it only gets as far up on the gauge as it used to when i woulkd plant. Am i crazy or is the mechanic wrong?? TIA
