Search Forums | Classifieds (22) | Skins | Language
8.3 cummins injector puller?
Adam Suess
Posted 4/4/2010 12:48 (#1149630)
Subject: 8.3 cummins injector puller?
Hanska, Minnesota
I've been attempting to remove the injectors from a 8.3 cummins. The first 4 pulled out very easy, then i found 5 and 6 stuck tight. I built a adaptor for a slide hammer and so far no luck. Is there a better puller available? Maybe a better way to remove these? The units I see on line look like specialized slide hammers. Thanks
