Fremont, NE | new 16R 1250 planter is getting factory fertilizer kit put on at dealer and they are using factory case orifices to regulate what flow we want and are using LD ag tubes to put starter off to the sidewall of the row. My question is do some of you guys running this planter use any kind of manifold to visually see that none of the tubes are plugged or doesn't anyone have that problem? The pro 600 monitor of course will regulate the flow but it won't tell me if any of the tubes are plugged I don't believe. What advice would any of you have on this subject? Pictures would be great also if any of you have them. Thanks
