Piedmont, NC | Left hand brake is not pumping up and have adjusted it and bleed the lines, I assume the master cylinder is bad. Is there one for each side or is it a double action single? Can I get one of these anywhere else like an after market? Also The boom lift jumps like crazy when you let it down unless you rev up motor. Which valve on the valve body controls this? Thanks!
Edited by GreenhouseGuy 2/28/2010 16:53
