![](/profile/get-photo.asp?memberid=7646&type=profile&rnd=302) Sheldon, IA | I am working on a 2588 with a factory 252 installed (CIH Branded). This combine used to have a PRO in it and now has an Insight. The Insight is getting GPS out of port B and the GPS is still hooked into the Combine harness and gets power from the combine through Port A. This set up has worked fine and has been mapping. Now the farmer wants to put his Ez-500 in the cab with ez-steer and would like to utilize the 252 instead of using 2 antennas. Where can I get GPS out of the combine harness to feed into the 500? There is no Pro in this combine any more, it is a 2008 model if that makes a difference. I would like to leave the Insight on port B and feed the 500 out of Port A. Is this possible? | |
