JD 568 error code
bkadds
Posted 5/14/2026 07:19 (#11645762)
Subject: JD 568 error code
Dalhart, Texas
What’s going on with a E02 13? We had a wire chewed on in the tube going to the right side. Fixed it, but still getting the code. Actuator moves when you go to channel 19, manually extend/retract and voltage seems ok when stalling it out during retraction-9.9 volts. Thought about switching tractors just to see if that helps.
