Search Forums | Classifieds (47) | Skins | Language
Round Baler HP requirement
ZeebaNeighba
Posted 4/4/2026 10:01 (#11606893)
Subject: Round Baler HP requirement
Michigan
I bid too high on a consignment sale and brought home a New Holland RB450 Crop Cutter. I've never run a round baler before and hadn't even thought about whether I had a suitable tractor to pull it. Am I reading the chart in the manual correctly? (see pic) Looks like I need 100hp. 122.5hp if I want to use all 15 knives. That would make my JD6330 insufficient. On top of that, it has four sets of hydraulic hoses and I only have 2 scvs. I could use the JD8200 (big 1000 only), but the baler is 540 pto. Do you think I'd do well trying to bale at an engine rpm of 1000-1200? I have in the past ran the old 336 square baler like this, but as I understand, a round baler doesn't need to run at max speed, and may not want to. Is there an easy/cheap way to change the gearbox to make the baler 1000pto?
The seller said he used a 75hp tractor with only two scvs, and never engaged the knives. I could do the same as he did. No knives is one less set of hoses to worry about, and less HP required. I wasn't too keen on his idea of starting by lifting the drop floor and then pulling those hoses under pressure. I could get a splitter.
I have a habit of making hay on my small hilly fields that I don't like row cropping on. Going uphill might really overtax the 6330, while going downhill will easily push the 8200 past 540.
Looks like I'm in the market for another tractor.
(IMG_20260403_170952827 (full).jpg)
Attachments IMG_20260403_170952827 (full).jpg (73KB - 40 downloads)
