swmn | The chelated manganese sulfate (in this case Versa Max Mn, 5% Mn, 3% S) is formulated to be used with AMS and glyphosate but the label states that it can be used with other herbicides as well. It also of course warns about potential herbicide antagonism and suggests a jar test.
Has anyone used this product, or similar chelated product, with Liberty? It will be applied in combination with Warrant for residual. Have you seen the manganese sulfate cause antagonism or had problems mixing? I know that the Liberty can be a bit fickle even on it's own. BTW, I'm just adding the Mn product based on a high ROI in previous Beck's PFR studies and my soil is marginally low in Mn. | |
