Search Forums | Classifieds (81) | Skins | Language
GPS Cable to Yield Monitor
eddycreek
Posted 8/23/2009 11:21 (#821286)
Subject: GPS Cable to Yield Monitor
West Ky, on Eddy Creek
I'm installing a PFAdvantage monitor on a 9500. About got everything on, and now need to get the GPS antenna/receiver cable to the monitor. It's got a 15pin connector made onto the end of it, so that has to go through the hole. What's the best route? It's a Garmin on a magnetic mount, and I assume the best location for it is at the front of the cab roof because of the bin extension overhang at the back of the cab. Is there an access hole someplace to get through? Is it better to run the cable across the roof to the back of the cab then down and drill a hole somewhere at the back of the cab? Or drill a hole in the roof, try to seal up the extra room for the serial end, and come in behind the radio?
Edited by eddycreek 8/23/2009 11:22
