Search Forums | Classifieds (119) | Skins | Language
Deere 2230LL Field Cultivator with tru set
Coastal
Posted 3/21/2024 15:01 (#10674090)
Subject: Deere 2230LL Field Cultivator with tru set
Having issues with the lift wheels and left wing not raising all the way up. Right wing not lowering?
Ive tried raising a lowering several times to phase the cylinders. Holding the SCV in lower and raise for several seconds. Disconnecting the ISO cable.
With it raised as high as it will currently go the Right hand wing cylinder measures 35.5" from pin center to pin center. While the left had is only measuring 32.5"
I fill like the center and left are not raising as high being that the rear spring tines are just barely clearing the ground. However, when in the lowered position the right side isnt contacting the ground.
Any ideas on what to look for?
