Search Forums | Classifieds (150) | Skins | Language
Semi truck driveline spline question
NTM Farms
Posted 2/29/2024 12:52 (#10645409)
Subject: Semi truck driveline spline question
Bloomfield MO
Rear driveline is getting new u-joints, so after removal I decided to clean it because it was telescoping as smoothly as it should. Finally got the two halves apart and noticed the blue plastic coating, on the splines is peeling off. This, along with old grease and dirt, was all of my problem. I cleaned both pieces really good and tried sliding them together but the plastic is tore to bad. What should or can I do. It’s a rear drive, driveline(26”) on a dump truck.
