Manitoba | My2014 Ram has 3 out of 4 doors that squeak badly. I’ve tried to lube them but it doesn’t seem to help. In the pic you can see the little roller which drags when it squeaks.
When I try to oil where the wheel spins on its axle it can help a little but if any oil gets on the outside surface of the wheel it slides and squeaks and creaks. I’m guessing Chrysler would say new hinges is the fix. The rear door hinges should not be worn out. Thanks.
Edited by MEJ 12/8/2023 09:46
(IMG_7259 (full).jpeg)
Attachments ---------------- IMG_7259 (full).jpeg (199KB - 78 downloads)
