NE colorado. & south central SD |
I keep getting gc-005 code, crop not refreshing fast enough in bypass then it shuts off the moisture sample auger. I replaced the auger motor and did find out the weather pack connection to auger motor would cause it to quit if it got jiggled. I replaced that also. When i turn off the separator the sample motor will run the 30 seconds to clean out the the auger.
Are there any other common issues to check.
(IMG_0667 (full).jpeg)
Attachments ----------------
IMG_0667 (full).jpeg (119KB - 91 downloads)
