Search Forums | Classifieds (53) | Skins | Language
Caterpillar Forklift
jimmyg
Posted 3/23/2022 13:22 (#9575771)
Subject: Caterpillar Forklift
North Carolina
It's an old VC60C and I'm assuming it has a cat motor but not sure. I bought it used and it has been painted sometime in the past. It has always started right up and run like a kitten, but all of a sudden I have to bleed the injectors to get it to start after sitting overnight. Once started it runs fine. I don't see a check valve on any of the fuel lines but something is letting the fuel back away from the injectors. The pump on the block between the tank and filter works good. Thanks for any help.
