Search Forums | Classifieds (51) | Skins | Language
Newer Versatile Cat transmission oil
north1
Posted 12/2/2021 22:20 (#9355791)
Subject: Newer Versatile Cat transmission oil
North Dakota
Have a 2011 versatile 575 with the TA22 caterpillar transmission. Have been running Caterpillar MTO in the transmission per operators manual. Have been told by transmission rebuilder you shouldn’t run multi-viscosity oil in a power shift transmission. Another oil recommended in manual is shell donax td which is a T0-2 oil like Mobil 424. Already use Mobil 424 in several pieces of equipment so would like to use that in the cat transmission as well. Curious what others are using?
