| I water pens of goats out of IBC tanks inside their cages cut off about a foot from the bottom. Run a hose connected to a 10’ pipe down into a float so there’s no hoses to be chewed up and quite a bit of fall for fast hose draining. Problem I have is the water doesn’t always get drank down fast enough and the TSC tank floats quite sealing when they freeze in the tank. Anyone got any suggestions for a good brand of float that will work the next day after it froze. Southern IN and rarely do we have a day that doesn’t get above freezing so totally freeze proof isn’t necessary. Just want one that will work for the warm 12 hrs day. | |
