Search Forums | Classifieds (51) | Skins | Language
Massey Ferguson 7622 fail to crank?
Larry_minn
Posted 11/4/2021 02:24 (#9303579)
Subject: Massey Ferguson 7622 fail to crank?
Bought a 1400hr 7622 last year. Liking it but from start. Sometimes you turn key, nothing. Raise foot off clutch, hear the click, nothing. Turn key few times, crank, instant start. (So safety for clutch likely working)
2 weeks ago it will not crank. MANY attempts (so it was not used on grain cart, instead undersized tractor used)
It started, but refused to move. Ok stop, restart CVT transmission. Zero crank. Side monitor has “transmission M8”. That MIGHT be different then normal. Battery box has more dirt, trash then I like. (The cover is lousy to keep dirt out, multiple electric boxes over batteries/ imo poor set up.)
I find checking neutral safety switches suggested. In past none were changed, just @5 twists of key.
Any easy fix? I have 2 easy days work for it to be done. But I can’t get it to start. (If it started I likely would drive field work strait thru, drive it to dealership, park it infront of shop door 5am)
