Search Forums | Classifieds (60) | Skins | Language
John Deere 8335R Code
farmhand1
Posted 10/27/2021 09:14 (#9289500)
Subject: John Deere 8335R Code
158.01 Electrical System Error
Cab load center control unit supply voltage low. Continued operation will result in restricted vehicle function. this is an error that comes up every once in a while. Had issue on day started tractor and would throttle up or move had tech out spent 3 hrs unplugging connections then replugging back in finally started working again but did not solve issue. Luckily never had that issue again but still get error once or twice a day for low voltage. Where to check first alternator and batterys? Any one else have this issue?
