Search Forums | Classifieds (85) | Skins | Language
challenger tractor won't move
Davidns
Posted 8/19/2021 20:25 (#9173535)
Subject: challenger tractor won't move
Ive got a 2004 challenger MT465B with 16 speed power shuttle transmission. It will not move after starting unless the f12 fuse is removed and the reinstalled, afterwards a 2: 1 code flashes and it can be driven if you only use the power shuttle lever. If foot clutch is depressed it stops moving and the fuse needs to be taken out again. The code is for the clutch pedal sensor , which I replaced and no difference. I also replaced a second switch on the pedal. Has anyone had a similar issue? This tractor would be very similar to the massey 5460. Thanks for any help
Edited by Davidns 8/20/2021 13:12
