Search Forums | Classifieds (43) | Skins | Language
CR Yield monitor
torn
Posted 5/5/2021 19:07 (#8989102 - in reply to #8988768)
Subject: RE: CR Yield monitor
roaming
FarmerE - 5/5/2021 12:54
Have a new holland CR 940 with the basic info view monitor and no data logger so i can see real time yield on the little screen but no way to log it. Can i add a intelliview monitor of some sort to act as the data logger and show mapping?. Combine is steered with trimble 750 so could gps be fed from the trimble to the intelliview. My thinking is that if possible i can buy a intelliview monitor cheaper then switching over to all trimble yield monitoring.
On a CR940, your options are limited. At one time, you could add an IntelliView Plus II, which was the display before the IntelliView IV. But NH doesn't offer the Plus II anymore, and they don't make software for the IV, as far as I know. If you manage to find a Plus II and want to go that route, keep in mind that the software will be black-and-white, not color.
Have you looked into the price to add a data logger?
