Adrian - 4/7/2021 01:43
mij - 4/6/2021 03:26
Your 10-34-0 mixed with N. is your problem. Do a jar test. Keep the jars for a week or two. Phosphorus
(poly-phosphate type) & N. mixed together don’t play nice they will eventually cloud up & turn to snot.
There are several different sources of phosphoric acid used when making 10-34-0. Some are dark black to a light green. My thought is it depends on the source & concentrations there of is what might allow you to use this mix one year & next year it’s a royal PITA. Sounds like you were fine till it sat for a day or two.
Good Luck.
I had this trouble in a pretty severe way this year. I've had it a little bit in years past, but this year my rig sat for 2 days with the saddle tanks nearly full, and it was a disaster. What can I do to prevent it happening again in the future? Any magic compatibility agent i can add?
Adrian
