JD Sd polyurea grease letting me down, what do you use?
HoRFarms
Posted 10/6/2020 06:11 (#8532310 - in reply to #8532139)
Subject: RE: JD Sd polyurea grease letting me down, what do you use?
SE VA/NE NC
mschultz - 10/6/2020 00:07
I am not an expert.
But, isn't the color of the grease "coming out" evidence that it is picking up contaminants that made their way into the bearings? If so, then the grease is doing a fine job and the color coming out is not the fault of the great.
I just do not see evidence there of grease failure- I just see dirty grease. So I don't think that it is letting you down at all- unless you can point to a bearing failure caused by a lack of lubrication rather than caused by contamination.
But like I said- just a hunch.
-Mike
Im less concerned with the color than i am the texture. I dont feel it should feel like silly putty in 10hrs use. But its a good point about contaminants.
