Search Forums | Classifieds (8) | Skins | Language
Hydraulic flow control valve ?
mafrif
Posted 1/11/2020 20:02 (#7967285 - in reply to #7967249)
Subject: RE: Hydraulic flow control valve ?
NC Iowa
http://www.princehyd.com/Portals/0/valves/ValvesRd100.pdf
S
hould work fine, will be super sensitive, if you are using it to fine tune exactly a spinner RPM it might be tough.  Make sure you get the set screw freed up and working so you can lock it down, and only loosen a little to make small adjustments.  Its the same as an RD150 on the above link.
