Search Forums | Classifieds (48) | Skins | Language
Massey 8650 Problems
rwrightsman
Posted 6/5/2019 07:49 (#7542346 - in reply to #7542294)
Subject: RE: double check all the battery connections and try these
t4151 - Thanks. Where is this sensor? It would be possible.
E4332 - I'll see what happens after it has been down for a while. The module is new as of Friday, so the filter is new too. I'm also thinking time to replace batteries.
E4356 - I tend to agree. I haven't been able to take that apart yet to check battery connections. The connector at the module was good, I checked it in the couple times it's been open. The power distribution box above the batteries was replaced last month. Everything then tested out ok, relays, wiring to the module, etc.
The tractor is a 2011, 2010 hours on it. I am not certain right now, but I think the batteries are original. Haven't taken that apart yet.
