south texas | This is just my opinion but if u have the stands and a nice shop, the split is almost as easy as just the pan and will end up with more success. Just the pan can be tricky sometimes.
If u do just the pan, be sure to put some sealer at the corners where pan, block and trans meet. Some 3/8 line up pins for the pan help. Use a floor jack to handle pan.
Have u checked the bolts to the transmission in the pan? | |
