Search Forums | Classifieds (39) | Skins | Language
John Deere 8410 or 8420?
shorty1
Posted 6/17/2018 08:17 (#6817010 - in reply to #6816882)
Subject: RE: John Deere 8410 or 8420?
The normal rate on a wide load tractor would be $4 a running mile.Just go to Yesterdays Tractors and post on Hauling Schedule and you will get several responses.I have names of some good truckers that I use.515-290-4336 or [email protected]. Wide loads require permits ,travel routes ,and daytime operation,which are required. As far as tractors we have had good luck with everything until the DEF and pollution devices came required in 2011 after that codes,regeneration, and phantom problems are part of normal operation. It not color blind either as every manufacturer is having issues. We actually sols an 8370R and replaced it with a 8320R pre emissions and instead of buying aa 9560 0r 70 went with 865C Cat pre emissions and also have semis that are 2006s for same reasons.Eventually we will all have to bite the bullet but for me not quite yet. The serial number check can show you some of past history.I deal in older 20/55 series tractors and there was a way to check 55 series as I have done it by removing panel and changing a fuse to different location.
