| There is a procedure to test the flip flop valve as Ed B. said. Just because you installed a new one doesn't mean it doesn't leak also it has happened. If that's not it it is probably the hyd. pump front seal. Could be the steering pump but it happens less often. The valve is there to reverse the steering logic when in reverse. It is activated by trans oil from the directional clutch. | |
