Search Forums | Classifieds (45) | Skins | Language
8970 transmission control vavle
coastalBend
Posted 12/7/2016 17:16 (#5682720)
Subject: 8970 transmission control vavle
south texas
Got my trans back in. 24spd. jd came to check Pressure. Clutch pressure is about half of what system pressure is. From reading tech, the clutch valve or gasket behind control valve are the only 2 things to do without disassembly of the transmission. Any ideas. Planning to pull control valve and let jd look at it. Jd just did the 2 spd bench job. I don't know if this includes the traction clutch or not.
I had control valve off summer of 2015. Didn't see any damage but don't really know what to look for. Lots of debris went through trans when 2 speed failed
