Search Forums | Classifieds (9) | Skins | Language
Can I manifold 2 propane tanks together ?
boog
Posted 9/5/2014 23:08 (#4058268 - in reply to #4058208)
Subject: RE: Can I manifold 2 propane tanks together ?
I have two 1,000 gal propane tanks teed together. One is top draw & the other is bottom draw that feed two in bin driers. I have pulled from both at the same time but normally pull from each one separately. They are also teed into the 2" line that runs from a 2,500 gal tank to our Top Dry and act as a back up supply for it. When feeding the TD, I run off of either the 2,500 or both 1,000. Have friends that have three 1,000 teed together feeding a TD.
