Search Forums | Classifieds (83) | Skins | Language
What do you run for starter fertilizer in corn and why?
BIGASH Farms
Posted 5/7/2014 23:59 (#3858545 - in reply to #3857591)
Subject: RE: What do you run for starter fertilizer in corn and why?
MN
bad farmer - 5/7/2014 12:21 as always I will ask have you considered fish, time and time again you will get more nitrogen in your plant by establishing root system to capture nitrogen that you have applied to the soil rather then just putting more nitrogen on or putting it closer to the seed. fish is not corrossive to you $200000 planter, i have put as much as 75 gal per ac of fish on top of corn, beans and wheat with no hurting germ, Fish serves as a great carrier, catalyst, and you can even use it to lubricate your roller chains(yes double purpose). most wont even consider it cause they only think with a n,p and k mind, but i think you have already learned you can only get so much with more n, p, and k. I buy water soluble micros that soil test calls for and add them and then also add them to a dry blend also. I feel i eliminated my fungal problems by building my copper numbers within two years, I add part of my soybean innoculant to my fish and it aids in keeping the inoculant cool when it gets to be so hot at the later warm part of bean planting season. yes it smells, but those little critters in the soil like that smell and those little critters are what will protect your seed from the bad little critters that make you loose sleep. Just some thoughts from a stay at home dad whois having a blast today
Where do you get this Fish? What exactly is it? Waste fishery products? Do you put it in the furrow? I have seen you mention that it is a type of amino acid, is that correct?
