Search Forums | Classifieds (50) | Skins | Language
Pro700 as a VT
Madsnake
Posted 3/9/2014 14:40 (#3743432 - in reply to #3742710)
Subject: RE: Pro700 as a VT
torn - 3/9/2014 22:36
Madsnake - 3/9/2014 00:35
Looking at way to upgrade spray rate control could I use a raven isobus set up and run through case pro 700 in magnum tractor? What unlocks would be needed?
Madsnake
yes, this would work fine. No unlocks needed unless you wanted mapping, data recording, prescriptions, or automatic section control. if you need any of those, you need the Task Controller unlock for $800.
Torn thank you for the help once again.
Madsnake
