NE South Dakota Clark, SD | The C3000 is the same monitor we sell with Great Plains planters. GP has singulation, spacing, etc. If White is using similar modules from Dickey John, you would have these also. I am not sure what they are using for modules. You should also have the ability to run the clutches and VRA through Integra ISO task controller this year. I get asked alot about ISO and compatability. The only answer I can honestly give is plug it in and see what comes up. If it is on the Ag Leader ISO list, you chould be fine, other wise it is "In Theory it could work" |
