LOL! If your system is CAN based half width I will be more than happy to help. If it isn't, then what I have done may still work but I would be guessing at this point. I assume you have the brown box display inconjunction with the GS2? If so, go to the "Info" page and see if there is a separate line for "Planter Control Box". If there is, then I would assume you have CAN based half width disconnects. I'm not claiming to be an expert by any means, but have learned a LOT about how our particular system works. |
