Search Forums | Classifieds (82) | Skins | Language
precision planting, ag leader or deere yield monitor
bigswede
Posted 7/15/2013 15:28 (#3210022 - in reply to #3208194)
Subject: Re: precision planting, ag leader or deere yield monitor
based on what i've seen of the PP setup it shouldn't be much of a hassle to install. Fairly straightforward. The major difference between PP and AgLeader is the location of the flow sensor and the replacement of the elevator chain. Its the location that is giving the PP version SPATIAL accuracy not just total load accuracy. Agleader has a very good system but it does require fairly constant calibration to maintain SPRATIAL accuracy as well to a lesser extent total accuracy. I've run the AgLeader system for years and its great, from what I've seen of the PP monitor it should maintain the total accuracy and increase the spatial accuracy over AgLeader enough so to help me refine my management zones which is what i'm using the maps for now. All that being said I don't have a green combine and likely won't....ever. So i'm out of luck for now.
Edited by bigswede 7/15/2013 15:30
