At the entrance to Sandbanks Provincial Park | You can do alot with the pump itself. We have an older Walker 75 foot booms 15 inch centres that we put 32 % uan on with . Could only go 5 mph putting on 45 gal/acre. Bought a new pump from Jensons in Illinois. The old pump had 1 1/2 inlet and 2 inch outlet. The new pump has 3 inch inlet and 2 inch outlet. Pump is a Hypro 9306C-HM1C-3U And was as close as you could get to plug and play. Pump came complete with hydraulic Motor. Just had to connect the hoses to the ports and was ready to go. Got the flange ports on the pump and was easy to connect. Old pump was also a Hypro. So with only changing the pump we can now apply 45 gal/acre at 7.5 mph. Pump and fittings was less than $900. Gained a lot for a small investment. Sprayer has a raven 660 with 2 inch flow control. |
