Search Forums | Classifieds (62) | Skins | Language
Ford TW15
lfc
Posted 11/9/2012 16:33 (#2688013 - in reply to #2687703)
Subject: RE: Ford TW15
CT
That will have an 8F-2R transmission (4F-1R with high/low range) with a Dual Power power shift in each gear to give you 16F-4R.
Many will argue (and it is pretty much true) that low range reverse it too slow, and high range too fast. Dual Power helps a little.
Remember that this is a dry clutch, non-syncro transmission with no forward-reverse shuttle - as basic as they get. With a little practice you can shift them like a pro, but forward-reverse will always require a complete stop.
Also realize that the transmission is almost bulletproof, and you won't likely ever have a $5000+ repair bill to fix it either. It all depends on what you want - it all comes at a price!
