Fresno, California | Change the fluid yourself, drop pan change filter, overfill by one gallon, remove return line at oil cooler fitting on radiator, run oil in a one gallon jug with a jumper hose, when full stop and refill Trans with with another gallon of transmission fluid, repeat until transmission fluid is clear, then fill to proper level, I've only done this on a Tahoe, once you figure this out it's quite simple, you might find something on Youtube.
George | |
