Search Forums | Classifieds (160) | Skins | Language
Joystick problem on 970 Quicke loader
69zfarmer
Posted 8/16/2011 16:36 (#1915153)
Subject: Joystick problem on 970 Quicke loader
North Central Alabama
I just bought a complete 2004 970 Quicke loader,brackets,joystick,valve to go on my CIH MX120.It was in the deal for me to take it off of another MX120 myself.I marked cables from joystick to valve,hydraulic lines at the power beyond block in back sandwiched between the remote blocks.I did not take hydraulic lines loose at valve.The valve is bolted to the right loader bracket about head high and the 4 loader lines plug in there.
Everything works fine except the float detent is all the way back behind raise posistion.The loader raises correctly by pulling the lever back but if you keep pulling joystick back you can feel it go into float and the loader will go down and float just like it is supposed to by pushing the joystick foward.
I talked to the mechanic that mounts all of the loaders on tractors at my local CIH dealer.He is pretty sharp and he was scratching his head trying to reccomend a fix.He said i may have to swap around my 2 cables coming from joystick in cab to valve outside mounted on loader bracket and then switch the 2 quick connect hydraulic lines at valve going to the lift cylinders.
I did not test the joystick on the sellers tractor before i pulled the loader and valve off but i bet it worked the same wrong way because i marked everything.
Please don't tell me to rotate joystick 180 degrees because it only goes one way and every thing works correct except this float posistion.
When you buy a Quicke loader does the joystick have to be put together and if so could the cable have been put in wrong at the joystick?
