Search Forums | Classifieds (135) | Skins | Language
epson salt on corn?
JohnW
Posted 6/6/2006 02:32 (#17433 - in reply to #17376)
Subject: Re: epson salt on corn?
NW Washington
Well epsom salt is magnesium sulphate and it should help for a quick fix if you need magnesium. Sulphur might help too. Dolomite or limestone with a lot of magnesium would be a better long term fix. Here is some salesman talk on using epsom salts in the garden.
"Magnesium and sulfur are the two major components of Epsom Salt. Crop researchers have determined that magnesium is:
A critical mineral for seed germination.
Vital to the production of chlorophyll, which plants use to transform sunlight into food.
An aid in the absorption of phosphorus and nitrogen, two of the most important fertilizer components.
Sulfur, the other major component of Epsom Salt, is also an important plant nutrient. Sulfer may:
Contribute to chlorophyll production.
Make the primary nutrients (nitrogen, phosphorus and potassium) found in most fertilizers more effective.
Although magnesium and sulfur occur naturally in soil, they can be depleted by various conditions, including heavy agricultural use over time. But unlike most commercial fertilizers, which build up in the soil over time, Epsom Salt is not persistent so you can't overuse it. Tests by the National Gardening Association confirm - roses fertilized with Epsom Salt grow bushier and produce more flowers, while the compound makes pepper plants grow larger than those treated with commercial fertilizer alone."
Edited by JohnW 6/6/2006 02:34
