Search Forums | Classifieds (19) | Skins | Language
Sparky, question on JD head skid plates.
sparky
Posted 6/19/2007 07:03 (#164244 - in reply to #164056)
Subject: Re: Sparky, question on JD head skid plates.
Owensville, Missouri
Ultra High Molecular Weight- It is used alot in packaging equipment to make surfaces slick so product will slid over it easily. Do agoogle for UHMW to find a supplier. I got mine from Cope plastic in St. Louis. I used a bullet bit to cut the heads of the remaing rivets then punched then out. Iused a air riveter with button head rivets. You can get them from Grainger or McMaster-Carr. Remember I did this on a rigid platform the flex might be different. Good luck.
