roaming | Yes, you will have to have a Task set up (that's required any time you're recording any data), but no need to set up an implement.
For Field Marks, just go to Toolbox > Marks, and create a mark called "Tile line". Set it as a "Latch" type. Then put "Field Marks 1 & 2" on any run screen or your left area. Then, when you get to the start of your tile line, press the "Tile line" button. It will turn black and a flag will popup in your upper left icon area. It is now recording a mark every 1, 2, or 3 seconds, depending on the logging interval you set in your Toolbox > GPS screen. When you reach the other end of the line, press the "Tile line" button again and it will turn gray and stop recording. | |
