Central iowa | Working on skidloader and only way get enough stall pressure to the unlock bucket unlock hydraulic cylinders is to raise boom lift up which isnt safe.. any input to why.. the solenoid at valve block works fine but not enough pressure to get past the check valve on unlock block.. stand by at loader unlock inlet fitting is 188 tell use another function even with unlock button pushed..everything else works as it should.
Edited by 01htec 8/6/2026 17:43
