Deere Ops Center
KevinSeidl
Posted 7/17/2026 09:40 (#11702788 - in reply to #11702784)
Subject: RE: Deere Ops Center
You "can" log pieces of a field it's just annoying.... The manual work recording just fills in the entire active boundary... so if you want to do half the field one day... you could copy the active boundary, split the new one, adjust to the right area to planted on the first day, save, make that one the active, then add manual work.... then go back, make the other half the active boundary.... add manual work again... then go back into Land and make the original boundary the active one. So it's possible but pretty painful.
