Search Forums | Classifieds (51) | Skins | Language
Heifers. Again,if you don’t mind…
WCWI
Posted 6/20/2026 13:18 (#11679781 - in reply to #11679718)
Subject: RE: Heifers. Again,if you don’t mind…
Not that hard, the ones that pile into the ring and start crawling over the ones that are pressed 1/2 thru the cables, then turn around and put the ring man either over the fence or into the man guard in the corner are the ones you do not want, good calm ones will show up when you compare groups.
