Kiukainen, Finland | Yes Rate and section control box 75774 for Field-IQ is what you need. It does the same things that the old EZ-boom did with an EZ-Guide 500 display.
You section valves seem to be the 3-wire ones. Those are battery +, battery - and control. So there will be one control wire coming from Field-IQ to each section valve.
If your sprayer has as flow sensor and electric flow control valve you can also do the flow control with the Field-IQ.
But it is also possible to use only the section control. | |
