Posted 9/10/2025 16:06 (#11360891 - in reply to #11360155) Subject: RE: Taper Lock Bushing on Shaft With no Keyway?
Does the grease provide better clamping action since even though it decreases friction when a layer is still on the mating surfaces, it becomes so tight it forces all of the grease out? You'd think if there was a microscopic layer of grease still on the shaft, it'd slip easier.
