Search Forums | Classifieds (95) | Skins | Language
Integra coverage log switch
farmerwalt
Posted 8/6/2025 08:37 (#11322424 - in reply to #11321074)
Subject: RE: FarmerWalt - Curious about configuration
Clifton Kansas
Sometimes we need to think outside the manufacture suggestions to make things work for our needs. Like you do. Sometimes just the little things can make life a lot easier on us.
With agleader new steer command Z2, you need to be making a coverage map for it generate the next pass guidance line if you are using smart path. Found that out the had way on a mile long run along a creek.
The app rate module can be a good tool to use in several places.
I thinking about make up a harness with a switch that I can move around easy so I can use it on several different pieces of equipment for better coverage maps.
